March 17, 2023 at 8:58 am
FAQParticipantSince the version 18.0, SCDM allows to import directly .TIN format files. However if we import the .TIN file which does not have Built topo done in ICEM then it may transfer all the separate surfaces in SCDM. If we attempt to have enclosed volumes then we can do built topo in ICEM so that it will transfer the volumes as solid bodies in SCDM.
- Skewness in ANSYS Meshing
