Tagged: 16.2, fluent, fluent-post-processing, fluid-dynamics, General, post-processing
January 25, 2023 at 7:16 am
FAQ
ParticipantThe surface on which post-Processing is desired should be available as msh-file (or stl) In Fluent go to Surface -> Imprint. A window pops. Press the “Read” button and import the post-processing surface. This is now listed under “Surfaces” of Display options like Mesh and Contours and available for post-processing activities.
- Skewness in ANSYS Meshing
