April 5, 2023 at 2:32 pm
FAQParticipantFrom the below given methodology please follow the step accordingly: 1. Created a 3-D volume, mesh the required surface with refine mesh and remaining coarse. 2. Import *.msh file in Fluent, default set-up, run Calculation/simulation just for 1 iteration. 3. Imported the *.dat file in CFD-Post 4. Export the required surfaces as *.csv format from CFD-Post using File–>Export 5. Imported the *.csv files of these particular surfaces to the original CFD-Post post-processing file using File–>Import Surface or Line Data 6. Plotted the required variable on these imported surface locations.
- Skewness in ANSYS Meshing
