April 5, 2023 at 2:31 pm
FAQParticipantIt may occur that SpaceClaim does not respect the “Facet maximum edge length” setting in the export options of the TGF-file export. This is related to the regional settings of the computer, i.e. when the decimal separator is set to comma. While generally SpaceClaim works correctly with comma as decimal separator, this is not the case for the TGF-file export. If this export is required, please change the regional settings to use the comma as decimal separator. On Windows 10 this is done in Control Panel > Region > Additional Settings > Numbers > Decimal symbol
