How to get the values of maximum and minimum for X, Y and Z deformation at a time in one row for remote point?
Tagged: 18.2, General, mechanical, static, structural-and-thermal, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantOne can use the User Defined Result with the expression as UVECTORS.
