How to get rid of the error: “cx-xy-plot-data: unequal length argument lists” even when no monitors are setup in the Fluent case?
Tagged: 2020 R1, fluent, fluent-post-processing, fluid-dynamics
March 17, 2023 at 8:59 am
FAQParticipantThis error is related to graphical plotting of data, which could be plotting of monitors or residuals. If monitors are absent and still this error shows up, turn off residual plotting from Monitors > Residual… panel. Run a few iterations (during which the error should vanish). Then the residual plotting be turned back on again.
- Skewness in ANSYS Meshing
