April 13, 2023 at 7:32 am
Solution
ParticipantThe point can be displayed by the following procedure. 1.Create point 2. Set the following on the Geometry tab of Details of Point * and apply -Method: Variable Maximum -Location: Surface or cell zone (Domain) to be displayed -Variable: Physical quantity whose Max value you want to check – You will also see the nearest node number on the same window .
- Skewness in ANSYS Meshing
