Tagged: 19, fluid-dynamics, General, inflation, meshing, pre inflation
April 5, 2023 at 2:33 pm
FAQParticipantIf your base is smaller than inflation height then try to use “Maximum Height over Base” to a number greater than 1. With this you will be able to get the inflation height taller than the base size.
- Skewness in ANSYS Meshing
