Tagged: 19.1, General, mechanical, static, structural-and-thermal, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantReaction force can be used to get the equivalent force load to applied displacement load. For this, go to the tree outline and drag the applied displacement down to the Solution object and it will add a Force Reaction item. Right click on Solution and pick Evaluate all results. The force reaction values are listed in the details window.
