How to get access to a Monitor Statistic, like an arithmetic averaged value, of a solver monitor point in CFD-Post?
April 13, 2023 at 7:32 am
SolutionParticipantIf a Monitor Statistic from CFX-Pre, like an arithmetic averaged value, is monitored during run time, this value will not be accessible in CFD-Post. To hand over the value to CFD-Post, an additional variable has to be created in CFX-Pre. In addition, by default, this monitored value can be shown in a Chart in CFD-Post, choosing Data Source=Monitor Data, without the Additional Variable need. Please refer to the attachments to access the Solution.
1. 2041349.pdf
- Skewness in ANSYS Meshing
