Tagged: 2020 R2, fluent, fluid-dynamics, General, General - FLUENT
March 17, 2023 at 1:10 pm
SolutionParticipantUsing the scheme file one-two_sided_wall_utils.scm will rename the internals in a consistent way with the suffix -solid for the internal adjacent to the solid cell zone and the suffix -fluid for the internal adjacent to the fluid cell zone. Please refer to the attached document to access the detailed solution. Keywords: Internal, Internals, Interface, Naming, Convention, Consistent, Inconsistent, Cell Zones, Fluid-Solid, Solid
1. 2063747.pdf
2. 2063747.zip
- Skewness in ANSYS Meshing
