How to fix the issue when obtaining the following warning message in Fluent Meshing? Warning: no nodes readanalyzing boundary connectivity…done.
Tagged: 2019 R3, FLUENT Meshing/Tgrid, fluid-dynamics, General, meshing
March 17, 2023 at 8:58 am
FAQParticipantThis warning message can occur when trying to import a 2D mesh file into Fluent Meshing and the path to the file is too long. The workaround is to save the msh-file in a new location with a shorter path and to import it form there. The Fluent Meshing working directory does not need to be moved, only the msh-file.
- Skewness in ANSYS Meshing
