April 5, 2023 at 2:33 pm
FAQParticipantWhen calculating torque or force in CFD-Post, sometimes the error: “Flow data – vertex count mismatch” is encountered. This was a defect that was fixed in version 18.1. Rerunning the solver, only one iteration is needed, in version 18.1 or newer will fix this problem. If it’s not possible to rerun the simulation in 18.1 or newer, the torque can be calculated on individual primitive regions.
- Skewness in ANSYS Meshing
