Tagged: 2019 R1, cad-import, FLUENT Meshing/Tgrid, fluid-dynamics
January 25, 2023 at 7:16 am
FAQ
ParticipantThe following error message may appear during import of a CAD model to Fluent Meshing: /file/import cad , “C:Users
DesktopHomeProjekteFluent TestSimplePipe_filesdp0FFFDMFFF.agdb” , 40 , m Importing one geom object per program-controlled and one zone per body … IntelSWToolscompilers_and_libraries_2016.2.180windowsmpiintel64bin was unexpected at this time. Error: Error in CAD Import Error Object: #f In this case check the PATH environment variable. It might contain a wrong entry as shown below: “C:Program Files (x86)IntelSWToolscompilers_and_libraries_2016.2.180windowsmpiintel64bin;” The error is the ; at the end of the path. Either remove the ; or the complete path entry to fix the issue. Keywords: Meshing, CAD, import, Python, PATH
- Skewness in ANSYS Meshing
