Tagged: 2019 R1, fluent, fluent-post-processing, fluid-dynamics, post-processing
April 13, 2023 at 7:33 am
Solution
ParticipantDepending on the Fluent version, you might observe that saving images with white background makes the text of the color map or of x-y-plots disappear because it has the same color as the background. You can change the foreground color with the text command /display/set/colors/foreground For more details, refer to the attached document. Keywords: ANSYS Fluent; post-processing; color; colour; legend; color map; text; line; not visible; invisible; visibility; save picture; image file
1. 2058638.pdf
- Skewness in ANSYS Meshing
