March 17, 2023 at 8:58 am
FAQParticipantTo filter your selection, click the white cursor arrow in the bottom right corner of the design window on the status bar to display the selection filter. This drop down menu that shows all selectable entity types. Turn off Smart selection, then toggle which entity types you would like to remain in your selection. Changing tools turns the filter back to Smart. SCDM retains these settings the next time you enable the selection filter.
- Skewness in ANSYS Meshing
