Tagged: 19.2, mechanical, static, structural-and-thermal, structural-mechanics, thermal
April 13, 2023 at 7:33 am
SolutionParticipantPlease see the attached short video clip that illustrates
1. heat_flow_through_contacts.mp4
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
