November 2, 2022 at 9:16 am
Watch & LearnParticipantIn this video, you will learn how you can transfer your simulation over to ANSYS fluent, to do in depth analysis of your simulation in our flagship product. To transfer Discovery data to another Ansys application, select the Transfer menu in the ribbon of the Simulation tab, choose fluent. Fluent will be launched with .cas.h5 files. Export to Fluent is disabled for Fluid simulations that contain faceted bodies. You can also transfer your data without launching Fluent. Select Save As from the File menu and specify a file type. Select Fluent CAS File to save as .cas.h5 file.
Please refer to this for further considerations before transferring: Considerations before transferring the file to flagship products
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Discovery – Defining new material
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Structural Simulation using Bolt Idealization
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Discovery Quick Tip- How to Export to Fluent
