How to export to Ensight from Fluent? Can I export from WB? What is difference in exporting Ensight file and reading Fluent file directly in Ensight?
May 15, 2023 at 8:33 am
SolutionParticipantPlease refer to attachment to access the solution. Keywords: read, import, fluent, case, data, export
1. 2053815.mp4
- Skewness in ANSYS Meshing
