Tagged: 16, BladeEditor, BladeModeler, fluid-dynamics, Preprocessing: Geometry
April 13, 2023 at 7:33 am
Solution
ParticipantCreate a separate Layer for the tip and set it as User Defined Layer in the Flow Path. In TurboGrid use Profile Number as Shroud Tip option. For more details see attached PDF.
1. CAD_to_TurboGrid_1.pdf
- Skewness in ANSYS Meshing
