How to export .stl from SCDM with Named Selections, to convert object names to named selection and to convert layer names to named selection in SCDM
April 13, 2023 at 7:33 am
SolutionParticipantPlease see the attached documents for the solution. The pdf was made with a previous version of SCDM. To install the addin in 2019R1, please Unzip the attachment in C:Program FilesANSYS Incv193scdmAddins The rest of the pdf is still valid in 2019R1
1. 2042111.pdf
2. 2042111.zip
- Skewness in ANSYS Meshing
