April 5, 2023 at 2:33 pm
FAQParticipantWorkbench meshing does not have plot3d export functions. Only ICEM has it. If you have mesh in Workbench meshing, then you can always connect ICEM component to WB Meshing and then export plot3d from ICEM.
- Skewness in ANSYS Meshing
