May 25, 2023 at 7:29 am
FAQParticipantRight click on the corresponding infinite sphere set up in Project Manager and select Compute Antenna Parameters>>Export Fields. Select ffd file format.
- ANSYS HFSS: Designing a Dipole Antenna – Part I
- How to export far field data in ffd format and not csv or txt?
- ANSYS HFSS: Designing a Dipole Antenna – Part III
- Importing 3D Far Field results within HFSS
- ANSYS HFSS: Antenna Synthesis from HFSS Antenna Toolkit – Part 2
- ANSYS HFSS: Overview of Antenna Simulation – Part 1
- I defined a Master/Slave boundary condition for a unit cell but get the error : Matching boundary process might encounter unexpected conditions because the contact maps are ambiguous. What could be the reason?
- How to export ffd from HFSS and import it into EMIT
- What’s the meaning of Mag_E, ComplexMag_E etc?
- What does antenna pattern mean in unit cell model of a phased array antenna? How do I plot the embedded element pattern?
