Tagged: 2019 R1, fluent, fluid-dynamics, General, General - FLUENT
March 17, 2023 at 1:10 pm
SolutionParticipantWhen you want to execute text commands, macros, journals or Scheme scripts after a calculation is fin-ished, you can use the case modification feature that is described in the ANSYS Fluent 2019 R2 User’s Guide, chapter 37.18. Automatic Initialization of the Solution and Case Modification. The attached document shows the process to export an EnSight Case at the end of a steady state calculation.
1. 2059179.pdf
- Skewness in ANSYS Meshing
