General
General
How to evaluate the inlet turbulence intensity to reach expected levels at the boundary layer edge?
    • SolutionSolution
      Participant
      A correlation exists to predict the decay of turbulence (represented by turbulent intensity) downstream of an inlet. This correlation depends on the properties of the fluid and the flow velocity. A study of different parameters inside the formula is conducted and flow free-stream velocity appears to be the most influencing parameter on the predicted level of TI. Please see attachment for further details.
      1. 2042913.pdf
