Tagged: 19.1, General, mechanical, static, structural-and-thermal, structural-mechanics
March 17, 2023 at 9:00 am
FAQ
ParticipantWe can plot reaction force on construction surface. To do so, first you need to turn on the Nodal Force option available under output control option in analysis settings. After that select the surface as location method, construction surface as a surface in detail view of force reaction to post process the force reaction on construction Surface.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
