March 17, 2023 at 8:58 am
FAQ
ParticipantSpaceClaim has interactive meshing tools that enable you to create a high-quality mesh directly on your model. You will have to enable this from ‘File -> SpaceClaim Options (this will open a dialog box) -> Customize -> Ribbon Tabs -> Mesh’. Upon enabling this option, the ‘Mesh’ ribbon will be added to your SCDM. The Mesh ribbon uses the SpaceClaim tools paradigm to set up meshing parameters, generate a mesh, and interrogate the mesh within SpaceClaim. Having the geometry and meshing tools in the same application helps streamline mesh generation and can reduce the time it takes to create a high quality mesh on complex models. If connected to Workbench, the geometry and mesh is then passed to downstream systems. Keywords: Mesh ribbon, SpaceClaim mesh, 2019R2
- Skewness in ANSYS Meshing
