May 15, 2023 at 8:32 am
Solution
ParticipantHere are the settings to allow ANSYS Electronics Solver to use ANSYS HPC (& HPC Pack) licenses in 2018.0 and Higher. PFA solution
1. Electronics_ANSYS_HPC.pdf
