How to enable 2021 R1 RSM to resolve mapped network drive (e.g. Z:xxx) to UNC path for RSM staging directory?
April 13, 2023 at 7:32 am
Solution
ParticipantDevelopment has offered a fix. Refer attached readme.txt and .dll files.
1. 2064488.zip
