March 17, 2023 at 8:59 am
FAQParticipantThe ability to insert 3D models into PowerPoint has been added in PowerPoint version 1810. 1. In the Parts list, select the parts that you want to export to a 3D model. As of PowerPoint version 1810, PowerPoint can’t display streamlines. 2. Go to File > Export > Geometric Entities, then select the GLTF 2.0 File Format, then name the file, then click OK. 3. In PowerPoint, go to Insert > 3D Models and choose the .glb file. Note that the same instructions also apply to embedding a 3D model into Word.
- Skewness in ANSYS Meshing
