Tagged: 17.2, Create Geometry, designmodeler, fluid-dynamics, geometry, Other
August 25, 2023 at 12:15 pm
SolutionParticipantPlease refer to the attachment to access the solution.
1. 2046108.pdf
2. 2046108.zip
- Skewness in ANSYS Meshing
