Tagged: 17.1, Drawing, Electromagnetics & Electronics, hfss, modeler
May 25, 2023 at 7:30 am
SolutionParticipantPerform the following steps: •Create a rectangle: the size is the same as the size of the board; located some distance above the board (see Fig.1). Consider snapping points to the board corners and then changing the Z coordinate of the position • Select objects that represent the base for the mask, i.e. top substrate and traces (see Fig.2) •Using Ctrl key, select the rectangle as well •Go Modeler > Surface> Project Sheet, indicate desired thickness •For resulting object, change material to Solder Mask •Repeat for conformal coating creating a new rectangle and selecting solder mask as a base 3D object
1. How%20to%20create%20conformal%20mask%20and%20coating%20over%20the%20board.pdf
- I got “I/O error when reading design” error message when opening an AEDT project with HFSS 3D Layout designs after a system crash. How should I proceed to recover my project?
- ANSYS HFSS: Creating 3D Components
- How to Export S-Parameters from HFSS 3D Layout/HFSS 3D Designs ?
- Error: Extracta view creation failed; extracta run failed: Create process failed with error 2: Could not find application extracta.exe.
- How to Set “Non-Model” Property to an Object in 3D Layout
- How to export a design from HFSS 3D Layout to HFSS 3D Classic?
- How to Create Bondwires in 3D Layout ?
- ANSYS HFSS: 3D Layout Cut Out Sub-design – Simulation and Post Processing
- ANSYS HFSS: 3D Layout Model from a Cadence Board File
