Tagged: fluent, fluent-post-processing, fluid-dynamics, GENERIC
March 17, 2023 at 1:10 pm
SolutionParticipantStatic Pressure and the X, Y, Z Velocity gradients can be displayed through Contour Plots (Postprocessing/Graphics/Contours). The gradient values are released from memory after being used in the plot calculation and thus cannot be accessed; however, some variables, such as Static Temperature will still be able to be accessed afterwards by executing the following text command: “solve/set/expert” and answering ‘Yes’ to the prompt “Keep temporary solver memory from being freed?”. In addition, immediately after displaying the contour plot of your desired variable, in the Contours dialog box, under the ‘Contours of’ dropdown menu, select Adaption…, then Adaption Space Gradient, then click Display. This will display the spatial gradient of the variable plotted immediately before.
1. 2042173.pdf
- Skewness in ANSYS Meshing
