June 6, 2022 at 10:32 am
FAQParticipantCells of negative volumes, meaning that they have numerically negative volumes which need to be corrected, can be displayed when checking the mesh. The following steps will allow you to check where these negative volume cells are located.
1. Go to Display > Grid
2. Select Cells in the Display Grid window
3. Select Size from Options, enter 0 for Maximum under Cell Size Range, and enter an appropriate negative value for Minimum. Select Cell Zones and click Display. By the above method, you can check the location of negative volumes, and then correct them.
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- Create Sections in Meshing
- How to reverse surface normal in SpaceClaim?
- ANSYS ICEM CFD: Basic Blocking
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- Fluent: Watertight Geometry Meshing Workflow
- How to Fix the Error: “Mesh Exporter does not Support Overlapping Geometry in Named Selections”?
- How can I create a 2D section from a 3D model in SpaceClaim ?
