June 5, 2023 at 7:05 am
FAQParticipantUpdateRegistry.exe -set -ProductName ElectronicsDesktop2017.1 -RegistryKey Desktop/Settings/ProjectOptions/ProductImprovementOptStatus -RegistryLevel install -RegistryValue 1.
