April 13, 2023 at 7:33 am
Solution
ParticipantThat is not possible. You could save the complete assembly as a separate file but the drawing sheet will always be linked to the geometry. When you create drawing sheets, you can change visibility of parts in the drawing sheets. This may help you in some scenarios.
1. 2058519.pdf
- Skewness in ANSYS Meshing
