June 5, 2023 at 7:05 am
FAQ
ParticipantCustom equations are saved to an XML file in the following location: %APPDATA%RoamingSpaceClaimSketchCurveEquationCustoms.xml If you do not see a newly saved equation in the list, open/create a new document or close and re-open the current document. If you want to delete all custom equations, simply delete this xml file. If you want to delete a particular custom equation, search for its name within this xml file and delete everything within ExpressionBundleXmlSerializeProxy tag for that particular custom equation.
- Skewness in ANSYS Meshing
