Tagged: 18.1, fluent, fluid-dynamics, General, General - FLUENT
June 5, 2023 at 7:06 am
FAQParticipantIts under /define user-defined. Below is an example for the same. ;;allocate 7 UDMs and initialise memory ;; 7 UDMs to accomodate ground ht, roughness, & 3 p-p quantities & 2 wt variables define user-defined user-defined-memory 7 Keywords: UDM, user defined memory, tui, allocate
- Skewness in ANSYS Meshing
