June 5, 2023 at 7:05 am
FAQParticipantOne can create COMBIN40 element in following way: 1. Change the Element Control under Geometry Definition to Manual 2. Create a longitudinal spring and then insert following command to change the element type: et,_sid,40 ! Combin40, Spring-Damper Element
