Tagged: 19, contact, General, mechanical, structural-and-thermal, structural-mechanics
March 17, 2023 at 9:00 am
FAQ
ParticipantWhen a surface is in contact with itself, a self contact is defined. In order to do this: 1. Select the same set of edges/faces for both the contact and the target sides. 2. Set the contact behavior to Symmetric.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
