Tagged: 19.1, General, mechanical, static, structural-and-thermal, structural-mechanics
April 13, 2023 at 7:32 am
SolutionParticipantPlease refer to the attachments to access the Solution. In this solution a general joint is used and stiffness is provided to the joint using Worksheet.
1. 2055308.zip
