Tagged: cht, Conduction, convection, discovery, heat-transfer, Internal Radiation, radiation, thermal
September 12, 2024 at 8:51 am
Watch & LearnParticipantIn this video, we will see how to apply Internal Radiation in Ansys Discovery. This will be significant when working with high-temperature conjugate heat transfer (CHT) cases, as radiant heat flux can become a dominant factor compared to convection or conduction.
You’ll learn two main methods for defining internal radiation: through the fluid-solid interface or using wall conditions and we’ll see how to define internal emissivity values.
Please refer to the documentation to understand this further: Internal Radiation
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Ansys Discovery: Topology Optimization
- Discovery – Defining new material
- Discovery Quick Tip- Understanding Contour Settings
- Structural Simulation using Bolt Idealization
- Thermal Analysis of Heat Sinks with Ansys Discovery
- How to apply bolt Pretension in ANSYS Discovery?
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery Quick Tip- How to Export to Fluent
