Tagged: ansys-fluent, fluent-meshing, Growth Rate, mesh, Tetrahedral
June 6, 2022 at 10:32 am
FAQ
ParticipantThere are multiple refinement methods when generating tet volume meshes in Fluent Meshing. Some are legacy and the two most commun options to defines growth rates for tet meshes are :
– Geometric : used when a global growth rate is used everywhere and no Body Of Influence are needed. The growth rate is defined in the Tet panel. –
Size field : used when multiple growth rate are defined at different places of the model and if Body Of Influence are needed. The growth rate is defined in the Sizing (Scoped or Functions) panels.
For both the Refinement Method must be the default : adv-front . For those 2 options the growth rate is based on edge length, not on cell volume.
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- Create Sections in Meshing
- ANSYS ICEM CFD: Basic Blocking
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- How can I create a 2D section from a 3D model in SpaceClaim ?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
- What is meaning of message: One or more objects may have lost some scoping attachments during the geometry update.
- What is the difference between patch dependent meshing and patch independent meshing?
