June 6, 2022 at 9:58 am
FAQ
ParticipantCyclic symmetry for transient structural analysis can be realized by inserting a Command Snippet with command CPCYC under “Transient” of “Tree Outline” of the model. Example:
/prep7
cpcyc,all,,1,,90 !!! cylindrical coordinate system 1, location increments 90 degree
allsel,all
/solu
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
