Tagged: 18.2, contact, General, mechanical, structural-and-thermal, structural-mechanics
August 25, 2023 at 12:16 pm
SolutionParticipantPlease refer to the attachments to access the solution.
1. 2051294.pdf
2. 2051294.zip
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
