June 5, 2023 at 7:05 am
FAQParticipantA method for creating a user-defined volume in CFD-Post is by applying the Isovolume method for a user defined variable. Assume that a user-defined volume is desired for z>0.5 [m]. Do the following: 1.) Create an expression iflag=if(z>0.5[m],1,0) 2.) Create a user variable Iflag equal to the CEL iflag 3.) Create an isovolume based on variable Iflag where it is equal to 1
- Skewness in ANSYS Meshing
