March 17, 2023 at 8:58 am
FAQ
Participant1) Create the points and then with the Move tool use the option Enter XYZ coordinates and manually enter the coordinates. 2) Write a text file using the commands show below and then open it with Assembly -> File. The file should follow this format: 3d=True polyline=False 1 0 0 1 0 1 1 1 0 1 1 1 2 0 1 2 1 0 3 0 0 3 0 1 3 1 0 The coordinates are defined as (Z, X, Y). Use as many lines as the number of points needed. Make sure that the units used are consistent. Keywords: Point, Coordinates, SpaceClaim, XYZ, Move
- Skewness in ANSYS Meshing
