Tagged: 17.2, Create Geometry, designmodeler, fluid-dynamics, geometry, Other
August 25, 2023 at 12:15 pm
Solution
ParticipantPlease refer attached Jscript which helps to create pattern with unequal distance in Design Modeler. At start of this script, specify following user inputs: – name of body which is to be patterned – number of copies – direction (only along X, Y or Z direction) – positive or negative direction – pattern distance To run this script, go to File – Run Script … and select this script.
1. 2045761.zip
- Skewness in ANSYS Meshing
