How to create material point using GUI? What are corresponding TUI options? What are TUI options for volume meshing in Fluent Meshing?
Tagged: 18.2, FLUENT Meshing/Tgrid, fluid-dynamics, General, meshing, Tetrahedrons, volume mesh
May 15, 2023 at 8:33 am
SolutionParticipantPlease refer to attachment to access the solution. A sample journal file is also attached. Keywords: volume mesh, material point, tui, gui, volumetric region, volume meshing procedure
1. 2052779.mp4
2. 2052779.zip
- Skewness in ANSYS Meshing
