Tagged: 17.2, CAD Import & Repair, designmodeler, fluid-dynamics, geometry, Other
May 15, 2023 at 8:33 am
SolutionParticipantPlease refer to attachment to access the solution.
1. 2045869_Axial_Flat_Split_periodic.pdf
- Skewness in ANSYS Meshing
